How to export parts as one
henry_feldman
Member Posts: 126 EDU
Sorry if this ends up a dup, but the post never showed up
I have a parts studio with threaded posts that I use throughout a project. I keep it separate (and another for nuts) just because otherwise the primary parts studio is chaotic and the parts don't need to directly relate (or maybe as you see they do).
When, in my assembly, I add the threaded rods to the parts they come out of, they are of course separate parts, mated with a fastened mate. This is fine in OS, and this part is reused multiple times in my assembly (along with the matching nuts).
However, it seems that when one exports to STL to 3D print this, the rod is a separate part as far as the slicer is concerned. Is there a way to make these (either in part studio, assembly or export) to make this one object (e.g. they way it would be if I used "add" on a feature) as far as the STL is concerned. I only care that they print as one...
Optionsøyvind_kaurstad Member Posts: 234 ✭✭✭henry_feldman said:_Dave_ said:Henry
No, sorry all the parts that you wish to boolean must be in the same part studio.
If I'm understanding what you are doing here correctly, it is the ideal case for derived parts.
5 -
Options_Ðave_ Member, Developers Posts: 712 ✭✭✭✭Henry
See link below for derived part help.
https://cad.onshape.com/help/index.htm#derived.htm#kanchor154
HTH5 -
Optionstom_scarince Member, Developers Posts: 47 ✭✭✭Your logic is impeccable, but it is no match for tradition. In other industry-standard mcad packages the function is called "derive" so we're kinda stuck with it. Change the name and we'd have other experienced cad users in here asking "Where the heck is the derive function?"5
HTH
Mate connectors are tired to a single part. When you do the boolean, the part changes and I assume it can't associate the mate connector properly. If you select the boolean in the other order, does the mate connector stay around?
