While in Assembly, is there a way to flip a part?
michael_higa
Member Posts: 5 ✭
New to CAD and studying it on my own so apologies if this is a stupid question...
I have a panel which I would like to stack one on top of another. Copying the part was no problem but I would like to flip every other panel where side A would face side A of the second panel while both are in the upright position. (hope this makes sense)... Put another way, if I had 2 quarters, I would like the head side of the quarter facing each other while both heads are upright.
I know I could do this in Parts Studio and just save it as another part but was wondering/hoping I can just copy/paste the part in Assembly and just flip it.
Couldn't figure it out. any help is appreciated.
Thank you in advance.
1
philip_thomas
Member, Moderator, Onshape Employees, Developers Posts: 1,381
Without adding any mates, it is possible to modify the position or orientation of any part or collection of parts using the triad manipulator.
Any location in the selected group can be moved to the origin
The Triad can be reorientated by dragging it onto any generated mate connection point
Any part or group of parts can have any of the primary axes aligned or anti-aligned with the z axis.
Bottom line - you can do anything you want
Here is the link to the help
https://cad.onshape.com/help/#triad.htm?TocPath=Modeling%20in%20Onshape|Assembly|_____2
Philip Thomas - Onshape0
You really have to play around a little with the mate connector system to get it.
