How to insert diagonal brace
jon_woellhaf
Member Posts: 92 ✭✭✭
I have a square frame constructed from 2x2 square tube. How do I add a diagonal brace?
Options_Ðave_ Member, Developers Posts: 712 ✭✭✭✭simply I measured your assembly across the inner diagonal corners.
Then I copied your existing tube and moved the face on one side so that the tube length egualled the previous measurement.
Next I sketched and did an extrude/remove for the 45° cuts on the ends.
See my video at the link below for a discussion and example of using planar mates to mate this part.
https://forum.onshape.com/discussion/2736/how-do-i-mate-these-parts#latest
5
https://cad.onshape.com/documents/03f49d0f25c7c3b949bb536b/w/010732b301d5f67d0149adaa
Assembly.
I want the model to look like it's made of four square tubes with a fifth square tube diagonal brace in the middle.
Jon
