Default value for a lookupTablePath?
dave_cowden
Member, Developers Posts: 484 ✭✭✭
How do you set the default value for a lookup table path?
When i set up a lookupTable path variable, i expect the default value to be the one selected via the 'default'
clause in the lookup table itself.
But what i find is that the value is empty until the user chooses a value from it, at which point, it is populated.
What is the right way to ensure that the initial value of a lookupPath definition field is set to the default values initially displayed?
The hole feature regen doesn't look at the lookup table. Only editing logic does and it only looks for changes to it -- and after the first change, the value passed in is correct.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc5
I'm not seeing that -- when I type the following, I get a correct default.
const lookupTable = { "name" : "choice1", "displayName" : "First Choice", "default" : "y", "entries" : { "x" : "1", "y" : "2", "z" : "3" } }; annotation { "Feature Type Name" : "My Feature" } export const myFeature = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Lookup table" : lookupTable } definition.p is LookupTablePath; } { // Define the function's action }, { /* default parameters */ });If you can post a small code snippet where this is breaking here, I'll log a bug.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0 -
weird. so with that sample, inside of an editing logic function, and inside of the body,
print( definition.p ) would give { "choice1" : 'y' } ?
for me in both cases, and before any user click, definition.p would be an empty set. I'll make see if i can make a simple document to repro-- may example is way too complex to post, so it coudl have a bug too.0 -
Ah, no -- I was just looking at the UI. Logging a bug.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
Ok. as a side note, the hole feature in std. works around this-- somehow. The code was a bit too complex, i gave up trying to figure it out.
In my case, for now the workaround was to do something like this in the editingLogicFuntion:
var lookupPath = definition.path
if ( oldDefinition == {} ){
lookupPath = lookupPath ( { 'choice': 'p' } )
this allowed me to continue as if it was populated as I expected. but of course this code is brittle because it is a duplicate of what's already in the lookup table.0 -
