boolean parts in assembly
christopher_williams787
Member Posts: 1 ✭
can you boolean parts in assembly. trying to 3d print my part as one piece.
@christopher_williams787 ,You can not perform boolean operation in assembly.You can derive all parts into one part studio and you can boolean it.
@Narayan_K How do you put or copy multiple parts in one part studio?
edit: Solved: https://cad.onshape.com/help/Content/derived.htm0 -
@christopher_williams787,You can derive all parts into one part studio and you can boolean it as suggested by @Narayan_K . Kindly refer below video for more detail.
@Bouwy, Kindly refer below video which will be helpful to you for copy parts from other part studio. You also use tranform operation to re position them.
3 -
Hi, but how could I put the part I derived to exactly location I want? The part only stay at center and I can't move or rotate it?0
Hi, but how could I put the part I derived to exactly location I want? The part can only stay at center and I can't move or rotate?0
With the transform function....
HWM-Water Ltd0 -
If your intention is to boolean them as positioned in assembly then you can also create a new part studio in context, copy part(s) in place using transform and boolean. This will allow you to update from assembly when position as well as geometry changes.2
