Problem with loft tool
Stamos
Member Posts: 6 ✭
I am trying to use the loft tool without success. I want to use the three square profiles with the two arks as guides. The loft works but when I try to use the guides doesn't work.
https://cad.onshape.com/documents/ae53c87f2786c7c6f72a25ba/w/18abc0401afe1bdfacdfffc0/e/6d9f3b2057c43acd7c3f6735
Your guides do not intersect with the rectangles, I have modified the near one in my copy, zoom in to the other corner and you will see the lines do not intersect, see:
https://cad.onshape.com/documents/56f55f6de4b09e43cb70da4b/w/1ce30c514a3fabe29e693267/e/2c3f5fe11fa207d7c93e1060
Graham
