How to select multiple lines with a lasso or window in android app
ramon_hamm
ramon_hamm Member Posts: 9
I made a circular pattern for a gear, 40 teeth x 3 lines per tooth, somehow it got exploded even though the circular pattern icon was still in the box where I 'show constraints'. Since then I have drawn other stuff on the same plane that I want to keep so I can't delete the sketch and selecting it all will just delete it all. Is there a lasso or select window or something? Takes 4ever to select 120 lines separately. From now on I'll make a new sketch but still need that tool.
Thanks!
R
  • ramon_hamm
    Why is android always the last in line for support? Hmmmmm
  • tgunr
    tgunr Member Posts: 45 ✭✭
     In SketchUp you can select an edge or face then use "Select->All Connected" or "Select->Bounding Faces" to quickly select everything.
