How to select multiple lines with a lasso or window in android app
ramon_hamm
Member Posts: 9 ✭
I made a circular pattern for a gear, 40 teeth x 3 lines per tooth, somehow it got exploded even though the circular pattern icon was still in the box where I 'show constraints'. Since then I have drawn other stuff on the same plane that I want to keep so I can't delete the sketch and selecting it all will just delete it all. Is there a lasso or select window or something? Takes 4ever to select 120 lines separately. From now on I'll make a new sketch but still need that tool.
Thanks!
R
Thanks!
R
Window selection has not yet been implemented in Android yet.ramon_hamm said:I made a circular pattern for a gear, 40 teeth x 3 lines per tooth, somehow it got exploded even though the circular pattern icon was still in the box where I 'show constraints'. Since then I have drawn other stuff on the same plane that I want to keep so I can't delete the sketch and selecting it all will just delete it all. Is there a lasso or select window or something? Takes 4ever to select 120 lines separately. From now on I'll make a new sketch but still need that tool.
Thanks!
R
We currently do have that option for iOS and for the web browser.5
Thanks!
R
We currently do have that option for iOS and for the web browser.5 -
Why is android always the last in line for support? Hmmmmm0
In SketchUp you can select an edge or face then use "Select->All Connected" or "Select->Bounding Faces" to quickly select everything.-1
