Find/Replace across multiple tabs?
adamohern
Member, OS Professional Posts: 216 PRO
Find across multiple tabs in the same document is available through the magnifying glass. Replace across tabs and search across documents is still to-be-implemented.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
I know about the magnifying glass, and it's good to know replace is coming. If and when you implement it, I hope you support regex capture groups!0
+1 for regex groups. A mention of what dialect of regex you implement would be essential, making that 'regex' text next to the checkbox a link to whatever dialect you are using would be nice too.
1 -
Makes sense. For the time being, the regex dialect is Java 8's: https://docs.oracle.com/javase/8/docs/api/java/util/regex/Pattern.html
Unfortunately, due to our architecture, we use a different flavor for regex work within FeatureScript match and replace functions: C++'s http://en.cppreference.com/w/cpp/regex/ecmascript
I am not enough of a regexp expert to tell you exactly what the differences are.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
