How to fillet the top of a cylinder
allen_stewart
Member Posts: 32 ✭
Hello All,
How do you give the top face of a cylinder a fillet?
Thank you
Thank you
Never mind, cant find the delete button
@allen_stewart , Kindly follow below step for performing fillet operation.
- Select the FIllet tool
. - With the Entities to fillet field active, select the edge or face of the part depending on your requirement.
- Change the fillet dimension as per your requirement. and press Enter to see the result.
- Click
to accept the feature.
Kindly refer below video for more detail.
0 - Select the FIllet tool
