How to fillet the top of a cylinder
allen_stewart
allen_stewart Member Posts: 32 ✭
edited July 2016 in Community Support
Hello All,
How do you give the top face of a cylinder a fillet?
Thank you
  • allen_stewart
    Never mind, cant find the delete button
  • viru
    @allen_stewart , Kindly follow below step for performing fillet operation.
    1. Select the FIllet tool fillet feature tool icon.
    2. With the Entities to fillet field active, select the edge or face of the part depending on your requirement.
    3. Change the fillet dimension as per your requirement. and press Enter to see the result.
    4. Click green checkmark to accept the feature.
    Specific delete button is not available in Onshape. But you can delete any feature and entity by right clicking on that and delete option will appear. Also you can delete any entity or feature by selecting and press delete button from key board.
    Kindly refer below video for more detail.
