Side Profile Outlines in Assembly When Items are Hidden
joshua_meadowcroft
Member Posts: 10 ✭
When looking from the side at this part is there a way to see the outline of the circular hole extrusion the peg is fitting into? And again, looking from the side is there a way to see the outline of the top edge of the floor? It would really help me to identify if the mates are located incorrectly. The extrusion is 3mm deep and the wide portion of the peg is 5mm tall. However the top flat surface of the is flush with the top of the floor. So, I think the mates locations are wrong. There's 8 of these on my project. It would be nice if there was an easy way to see it before reworking them. I'm fairly new to this, so it would take me a while. Any thoughts? I hope the questions is clear.
The "Shaded with hidden edges" view mode might be what you're asking for.
5 -
@joshua_meadowcroft, You can also use "Translucent" and "section view" option apart from "Shaded with hidden edges".
1) Translucent:
2) Shaded with hidden edges:
3) Hidden edges visible:
4) Section view:
5
Note: There are 2 pictures loaded here. The image to the 2nd one is below the image in the text.
I would use a combination of a section view (https://cad.onshape.com/help/#moving.htm?Highlight=section view) and/or setting part opacity (https://cad.onshape.com/help/#appearance_editor.htm#kanchor32) so that you can see through the parts.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com0
5 -
Bingo. Thanks Kevin. Perfect. My suspicion was correct. The mates are off.
1) Translucent:
4) Section view:
5
