Loft guide from multiple edges
oran
Member Posts: 2 ✭
Hi,
When lofting a surface:
How do I select a guide that's composed of multiple segments?
Thanks
Thanks
You can create a full sketch as a guide. So if you put all segments for a single guide on a single sketch, you can select that sketch as a single guide.
@oran, Refer below thread which will be helpful to you for creating loft feature with guide.
https://www.onshape.com/cad-blog/introducing-lofting-in-onshape
https://cad.onshape.com/help/index.htm#loft.htm?Highlight=loft
