Planes normal to a curve (multiples)
andreas_lazzarotto
andreas_lazzarotto Member Posts: 2
Hello
I just found this Feature script :
https://onshape.zendesk.com/hc/en-us/community/posts/209877248-Planes-normal-to-a-curve-multiples-
Would it be possible to modify it so that you can place parts along the curve on scketched points, and not only by number of parts on the path or constant distance ?
I'm not really into programming, and I don't get all the logic needed to do those kind of stuff....:blush:
Thanks by advance !
Andreas
