circles are appearing as hexagons
rick_chapman
Member Posts: 24 ✭✭
I have a lot of circular shapes that once I go to view it in an assembly the circular items appear with flat sides.
Is there help for this?
This appears to be a tessellation problem. If you could please file a feedback ticket in the document and share with support we will be able to take a closer look. Please note that on the back end this is still being viewed as a circular shape so how it looks will not affect how it is supposed to behave in the assembly.5
In the document, click on the question mark icon (?) in the top right. Under this menu there is an option for feedback which will allow you to submit a ticket. You can do things like capture a screenshot and/or choose to share the document with us.5
I had too much resolution showing in the drawing. For example I had threaded rods with the actual helix of the threads cut in. Since there are some 225 of these rods in the drawing I think it was getting dragged down.5
Thanks, and I will send in a feedback ticket if I can figure out how.0
