Export Face as .dxf
janek_chojnowski
Member Posts: 1 ✭
Hi Everyone
I am looking to export the Front Face from the part attached to .dxf for CNC pathing. (Please see attached screenshot)
I only seem to be able to export one face section at a time.
Any help would be appreciated.
Many Thanks
Many Thanks
Have you tried using the Onshape app Kiri:Moto?0
What I have done is to create an empty drawing (no title block or borders) with just a single view of the face you want to export. Then you can export the drawing as a dxf and it will have all the curves.0
@robert_morris that is what I would suggest. Gives you the best option to nest profiles and export to model space.Lou Gallo
Sr. Director of Product Definition. UX and Support0 -
@robert_morris's solution isn't working for me. Here's a screenshot of the shape I need to export. Alternatively, is there a way to measure total perimeter length in OnShape? That's what I'm actually after, but I can't find that feature, so I figured I would do it with a vector editor.
@CaptainBisquick, Here is another option to try that I've done.
Create a new sketch on that face, then select all the edges that you want to export and click the "Use" button. Exit out of the sketch, right-click on the sketch you just created in the feature tree and select export.
That should put just those edges into the dxf/dwg for you.1
