cannot snap to origin in sketch mode
alex_lototzky
Member Posts: 5 ✭
I am creating a second sketch in a part, but I want to create a construction line from the origin but cannot snap to the origin!
I also cannot move the coordinates of the line to coincide with the origin after creating the line.
What am I doing wrong
also: I see that "s" is the shortcut to snaping. If this is a toggle function, where do I see if snap is on or not
In Assembly studio,"S" is shortcut of "snap", but in part studio, "S" is shortcut of "sketch". Which studio are you working in ?5
This should be possible (see GIF below). Feel free to file a feedback ticket if you think you are seeing a bug.
Hi, I have problems snap line or rectangle to the orgin? I either get a horisontal or vertical constrain?0
