How do I drastically narrow the filleted, but square end of a part?
Liam8253
Member Posts: 1 ✭
As you can see, the end of the part is filleted, but I need it to be triangular(ish). Can anybody help me? 0
Can you try a chamfer? Also maybe try turning off tangent propagation and only select the edges that you wanna fillet.0
Also if you can post a link to the document I can look at it!0
