I have drawn a box. I want to first determine its' dimensions and then change them.
bill_hayes
Member Posts: 5 ✭✭
I have drawn a box. I now need to determine the dimensions of the box and then change them. I know nothing about CAD software so just assume you are issuing instructions to a computer. Thanks
When youre on sketch mode, press 'd' or choose dimension from toolbar. Select one or more edges to see the dimension, click to place and set new value if necessary. Double click value to edit.
I would suggest to take few of Onshape tutorials to get properly started.
//rami0 -
Have you taken a look at the available tutorials?
Arul Suresh
PhD, Mechanical Engineering, Stanford University0
