Problem with plane and sketch
grzegorz_kondracki
Member, Developers Posts: 23 PRO
Hi,
I am a new user and trying to write a feature script. I have a little trouble with this, especially with the plane and sketch.
I have two points and I want to take the third in the middle between them - I can handle it.
Then I want to do prostodłą plane to the line between the points and passing through the center point. Then make a sketch and the sketch done section. From the drawing in a sketch that I can handle it. The problem is this plane - something I do not understand the instructions. Request for help.
My FeatureScript
https://cad.onshape.com/documents/95058ccda323af801590a69c/w/35e2eb3d6b3a8600b7c805f7/e/8c1ced1e3455e40bd4d61209
My FeatureScript
Hi @grzegorz_kondracki,
I'm not sure, but it sounds like you're trying to create a midplane between 2 points and then start a sketch on that plane. Check out the link below. I think this FS does what you want.
https://cad.onshape.com/documents/57c70029954b62117e75a28b/w/60ce13cf96608fbc06ef090f/e/33530b699ef75111e306dded
1 -
Hi Mahir,
Thank you very much for your help, that was my problem. Now I already understand. I have to repeat myself knowledge of vectors :-)
Sorry for my English, I know that is not strong. In addition, I made the mistake, not I used English words. Sorry again.
1 -
OMG someone else who's using analytical faces for planes. Love it!
At least skRectangle is trying to be an analytical face.
