DXF Breaks on Export,
sean_willmott772sean_willmott772 Member Posts: 6
edited September 2016 in Community Support
Ok I run a laser cutter and use a software called LaserCut 5.3 on one machine and a program called LaserCam on the other so far everything has been running swimmingly but after a file purge and clean up I am now having an issue on export of a file its quite a simple drawing and I have no idea why its now breaking apart.
Firs time around it was fine I am not sure what I have done or what's going wrong, checked all DXF versions with the same thing happens so any help is much appreciated.
  • mlml Member Posts: 53 PRO
    have had - beside others - the same issue: https://forum.onshape.com/discussion/comment/20530/#Comment_20530
    used the feedback tool and got a fix some days later
  • sean_willmott772sean_willmott772 Member Posts: 6
    Thanks ml I am not  a Pro member as yet, so not sure If they will be in a hurry to help and that's fair enough.
    Just totally confuses ne why this is happening now.
    Speaking as a free user (turning pro today hopefully) I've been hugely impressed with the support given by OS to users irrespective of whether they're free or paid.
  • GWS50GWS50 Member Posts: 507 PRO
    Agreed the support in OnShape is unparalleled and extremely refreshing.
    Ok that's Awsome to hear, I really want to make this work other wise I will have to look at something else.
    I think I have this solved now, looks as though it was two different errors but causing the same kind of issue one related to version LaserCad the other is to do with LaserCut after updating the LaserCad it seems to import ok but LaserCut is still causing issues but I am also having errors now from the controller, think I will just replace LaserCut with LaserCad something I have been going to do for some time anyway and make them the same.
