Loft guides creation?
JlabsJlabs Member Posts: 28 ✭✭
I'm having trouble understanding the order in which to create features in order to get a good, controllable loft. How do you create loft guides between two points? I've tried creating the loft, then creating a plane from the angled loft, and using that to sketch guides. But I can't use the guides I then create because I can't updated the loft without messing up the plane, and therefor breaking the sketch! Do I need to manually create a plane between my two sketches in order to create loft guides before creating a loft? Is there a better way to do this?
