perpective views in drawings
martin_streat
Member Posts: 2 ✭
Hi is it possible to make the isometric view on a drawing sheet into a perspective view?
3dcad
Member, OS Professional, Mentor Posts: 2,476 PRO
I don't think it's possible and thinking the history & use of drawings I wouldn't expect such improvement anytime soon.
You didn't mention why you need such drawing but there is workaround, in modeling space select 'hidden edges removed' from small view cube:
You can then take a screenshot and insert that image into drawing - a bit hassle and image needs to be manually updated if model changes but for occassional use it does the job.
//rami6
