How does one select for defining an extrude?
bob_harris
Member Posts: 2 ✭
When I started a project last month, whenever I wanted to add an extrude, it was easy to select the sketch. Now, once I have made an extrude, I cannot get back to the sketch to make an additional extrude.
I am trying to build up the lid to an electronics enclosure. I first extruded the flat surface that will become the top. Then I formerly was able to extrude the outer edges to form the walls using rectangles in the base sketch. I can't seem to do that now.
After you use the sketch for an initial extrude, Onshape auto-hides the sketch so that it is not in your way. If you go to the feature tree and hover over the sketch you want, you can either right-click on the sketch and select "show" OR you can select the crossed-out eye icon to the right of it.
6
6 -
Thanks Bradley. That got me back on track.
1
