How do you Mirror a feature that was created with Extrude Remove?
I am trying to Mirror two Extrusions that were created with Extrude, Remove (they are a nut slot and a hole).
I cannot select the two extrusions in the "Entities to mirror" box".  The only thing  I can select is the whole part (Part1 in this case).
Thank you.
  • brad_nelson537
    brad_nelson537 Member Posts: 2 ✭
    Thank you both.  It worked!!!
