How do you Mirror a feature that was created with Extrude Remove?
brad_nelson537
Member Posts: 2 ✭
I am trying to Mirror two Extrusions that were created with Extrude, Remove (they are a nut slot and a hole).
I cannot select the two extrusions in the "Entities to mirror" box". The only thing I can select is the whole part (Part1 in this case).
Thank you.
Thank you.
When the Mirror dialog box pops up, you'll need to use the drop-down box to choose "Feature Mirror" instead of "Part Mirror". Then you can choose features instead of parts, and it should work for you
6 -
@ brad_nelson537 , Try with feature mirror or face mirror instead of part mirror.
5
6 -
5 -
Thank you both. It worked!!!0
