revolve will not work when axis is within part
Hello, I'm new at this. I put a circle centered on the origin and a construction line down the center, When I revolve the circle around its axis I get a revolve error: "revolve did not generate properly - revolve would create self-intersecting part". If the axis is outside the circle it works fine. So my guess is that there is another way to create this 3D volume.
Thanks
Jacques
