How do i stick fins on a cylinder in an assembly?
matt_farkas
matt_farkas Member Posts: 8
Extruded a circle to make a (hollow) cylinder. Don't see how to add mating connectors in the extrude. In the sketch, it's just a circle.
Made a separate fin part.
Yah, I'm new to CAD and Onshape.
  • TimRice
    TimRice Member, Moderator, Onshape Employees Posts: 315 image
    If you dont mind your document being public, you could share a link to it here and we could take a look at it directly. Alternatively, if you would like your document to stay private, feel free to submit a support ticket.
    Onshape, Inc.
  • jackson_king
    jackson_king OS Professional Posts: 80 PRO
    How many fins are you looking at adding in the assembly?
  • matt_farkas
    4 to 16, depending... in this case four an arbitrary point from the bottom, but might like to add more higher, later (they are to guide the tube into a square container)
  • matt_farkas
    the fins have a flat bottom that will be welded to the tube... is this the problem? onshape can't mate a flat surface to a curved surface? or do i have to put mate points manually? i saw in some other discussions folk mention this, but i have no idea (can't seem to sketch on the curved surface of the extrusion)? there must be an easy way to do this... a colleague described how to do it in solidworks in several steps (i.e., stick flat edged fins on a tube)... i don't see any curvy examples in the tutorials... perhaps some should be added?
  • TimRice
    I think in this case you would be better off modeling the parts in a Part Studio. This will give you much greater control over the location of the fins on the tube. In general, the assembly studio is best used to check dynamic movement and relations between mates and is not as well suited for static assembly of parts.
    Onshape, Inc.
  • matt_farkas
    you mean like this: https://cad.onshape.com/documents/64fc2f49c879e9a688bb3444/w/9b3173d52b7fe439b8b0c941/e/c741e4c2819c989791748cba
    but then how do i add more fins higher up? do i have to extrude the full length then cut out what i don't want? even the current drawing is wrong in that the real fins have a flat edge that will be welded, but in parts studio it made a nice curved edge...
    if assembly is all about moving parts, why have the fasten option?
    so i guess you're saying there's no way to stick fins on a curved surface in onshape?
  • matt_farkas
    THANKS!!! i'd tried to do that (with a point, a line segment and a plane) but failed.... once i knew it could be done that way, i figured it out (that re-align is a bit odd for this newby)... i knew there had to be a straightforward to do it
  • matt_farkas
    note (in same project) i figured a sort of hokey way to do it with extruding and "fixin'" the parts in the assembly... seems like it could cause problems at some point; looks fine and can do a drawing with it; thanks again
