Using end conditions within the loft command
tim_waldemer
Member Posts: 10 ✭✭
Is there a way to get the surface loft commend to use both end conditions and guide rails at the same time, or am I missing the boat on this one?
Optionstim_waldemer Member Posts: 10 ✭✭Thanks Philip for the speedy reply. I've been adding end conditions to lofts that contain guide rails for years in other cad packages. Its important that the guide rail sketches (or edges) terminate normal to the sketch plane in all cases. Without being able to add the end condition (along with the guide rails) you must carry the "guided" loft surface through the normality plane using the sketch (with normality lines to the plane within the sketch(s)), and then trim off (or split in Onshape) with the plane to get a normal (perpendicular) end condition with the plane. Its a bummer that Onshape lofts don't support using end conditions and guide rails together.5
