multiple select
papawo
papawo Member, Developers Posts: 206 PRO
 Im trying to select a point then create a circle and loop again.
where can i insert the sketchId so i can have a diff Id everytime it loop.
 for (var i = 0; i < numberOfPoints; i += 1)
        if (definition.TypesOfHoles ==TypesOfHoles.TRANSOMHOLE )
            sketchId = sketchId + i;
            skCircle(skTransomHole, "circle1" , {
                    "center" : vector(0, 0) * inch,
                    "radius" : .25 * inch
            skSolve(skTransomHole);
            println(sketchId);
  • kevin_o_toole_1
    kevin_o_toole_1 Onshape Employees, Developers, HDM Posts: 565 image
    Sketch ids, unlike feature ids, are just plain strings. So the overloaded "+" operator that makes a sub-id doesn't work.
    FS string concatenation uses the "~" operator, so you should instead use e.g.:
    sketchId = "someId" ~ i;
  • kevin_o_toole_1
    edited October 2016
    Sorry, I misread your code and your question. Let me give a better answer.
    You can insert a unique sketch id as the "id" parameter in the call to skCircle, e.g.:
                skCircle(skTransomHole, "circle" ~ i , {
    Also, you should call skSolve only once, at the end of the sketch feature, after all entities have been added to the sketch.
  • papawo
    edited October 2016
     I tried what you suggested and picked 2 points but it doesnt do the 2nd sketch,
    i added a  println( "circle1"~i);; and it shows me diff   Id
                skCircle(skTransomHole, "circle1"~i , {
                println ("a");
  • kevin_o_toole_1
    You won't see two circles unless you place them in different positions. Your current code puts both circles centered at vector(0, 0) — the origin of the sketch.
    To get the circles positioned correctly, you'll need to calculate the position of each circle as a 2D vector on the sketch plane, and pass that vector as the "center" argument of skCircle.
  • papawo
     can you please show me an example.
  • kevin_o_toole_1
    The position of the sketch (and the position of the circles within that sketch), will need to be calculated based on what you want this feature to do.
    Here's an example that takes in sketch points and draws circles around them on their sketch planes:
    https://cad.onshape.com/documents/75e57c1e19ec6d534fb18b97/w/24279c587ff21cf8bd9ae49b/e/a32b15596565802fe644c917
  • papawo
    edited October 2016
    im new on this and thank you for giving me direction ! :)
  • papawo
    how to make this item as "answered"?
