help with extrude
Hi
I wanted to add a tank on the tube that i build so I make an extrude (remove) and a extrude (add) but when I did it the tank started from the middle of the tube and not from the outside of it.(like in the pictures)
How can I fix it?
  • owen_sparks
    owen_sparks Posts: 2,660 PRO
    If I understand you correctly:-
    (1) You could make the tank with the sketch outside the tube then use "extrude up to part" or "extrude up to face" option.
    or
    (2) Keep what you have and use another extrude remove to get rid of the bit you don't want.
    Cheers,
  • ofir_shapira
    ofir_shapira Posts: 4
    edited October 2016
    Hi @owen_sparks  I think you don't correctly understand the tank has the tube shape(it isn't rectangle) and I want that it will be on the tube and not inside it
    thx.
  • ofir_shapira
    Hi @Narayan_K I succeed thx.
    I have another question in a different subject.
    I want to remove the circle in picture so that will open with the tube below(there will be water there so they could pass)
    how can I do it?
  • Narayan_K
    Narayan_K Posts: 379 ✭✭✭
    @ ofir_shapira, Please find the below video,
