Grouping with dwg sketch import
trampas_Stern
Member Posts: 4 ✭
I have a dwg with lots of lines, when I import it the origin is off, see other post. However when I try to constrain the dwg to a point it will only do one line at a time, is there a way to group the lines of dwg such that I move and constrain them all at once?
You can do a box select of all the lines and then transform them: https://cad.onshape.com/help/Content/transform-sketch.htm0
Senior Director, Technical Services, EMEA0
