Parts/subassemblies update automatically
Dan_Engerer
Member Posts: 63 PRO
We have an assembly with sub-assemblies in it. When I change something in the sub-assembly, it does not automatically update in the top level assembly, and I'm not even able to update it in the top-level assembly unless I create a new "version" for the sub-assembly.
How do I get the sub-assembly to automatically update in the top level assembly? I absolutely cannot be creating new "versions" for things every time I make a little change during the design phase, which is about every 30 seconds. I will soon have hundreds of versions which I'm not allowed to delete.
I've just now noticed that OnShape seems to be inconsistent when it updates parts which have changed as well. Sometimes the changes flow through, sometimes not. What's up with that?
Looking forward to your answer.
1
NeilCooke
Moderator, Onshape Employees Posts: 6,044
Hi @dan_engerer - if your parts and subassemblies are linked from other documents then they will only update when a new version has been created and you specifically update the linked docs in your top level assembly. This is done to ensure that references are robust and do not change every 30 seconds. Parts that are in the same doc update instantly.
Senior Director, Technical Services, EMEA5
Actually, looking at the images again before pressing "post comment" - are you moving the parts in one assembly and expecting them to move in the other? All subassemblies are "flexible" by default and can move independently from one another unless the parts that make up that subassembly are mated or grouped together. Fixing all the parts in one subassembly does not stop them moving in the other, but grouping them will.
