extrude problem
simon_sjöstedt
Member Posts: 3 ✭
Hi. I need some help with an extrude. I want to make a bigger extrude around a smaller one without make it solid aigen.
If I understand - the main solution is having just two sketches (front and bottom). Then you will have regions to choose when you extrude. You can also use the new part setting in extrude for the cuts; then boolean union the parts. here is an example I did from your document - https://cad.onshape.com/documents/5838cd39df39c110362e0536/w/74a9fc15f3ab611e882ba856/e/9cfda80a9344e2c4cd76228d
Also, in most cases sketches should be fully constrained without using 'fix'. Instead use dimensions and normal constraints. For more information see https://www.onshape.com/videos/dimensions-and-constraintswww.accuratepattern.com5
I think we'll need more info or a link to a public doc.Senior Director, Technical Services, EMEA0
https://cad.onshape.com/documents/581d0c3248ac6210957dfd84/w/427911cb9f6d20892c163145/e/ac2e7dcb538985739fdb8e71
the problem is that a want to cut the edge 5x5 mm around the curved part to fit a lens inside. When Im trying to make a extrude around the smaller extrude it fills the inside and then its one solid pice aigen.0 -
Also, in most cases sketches should be fully constrained without using 'fix'. Instead use dimensions and normal constraints. For more information see https://www.onshape.com/videos/dimensions-and-constraintswww.accuratepattern.com5 -
My greatest thanks to you. I have tried to constrained without using fix but some parts wouldn't work so i used fix for everything as an easier solution. I will test some more to see if i can make it without fix but I´m just a beginner at cad.0
