view turned upside down
Hi!
Something weird happened to my assembly. When I inserted a new part, the view changed: when I click Front view, the parts are shown from the back and, when I click Bottom, then the top view is shown. What went wrong and how can I restore it?
This is link of the assembly:
https://cad.onshape.com/documents/a5b3d55095423fd06332ce56/w/543e2b390832a4dd9362d6d4/e/f7a410bf82f24262f19c5c63
Any ideas welcome!
Tivadar
  • viru
    viru Member, Developers Posts: 619 ✭✭✭✭
    @tivadar_kecskes, The view is changed because you may be unknowingly dragged the instances. After insertion of any part in assembly the default positioning is the alignment of the Part Studio origin (of the part or subassembly being inserted) with the Assembly origin (of the assembly being inserted into). I checked in your assembly it working fine. Onshape automatically records the state of each tab (Part Studio, Assemblies, etc) at each persisted change made to all tabs for every workspace by every user. This history of modifications is listed in the flyout. At any time you can click Restore to restore the branch/workspace to a particular point in its change history, click Return to <branch-name> to return to the currently active branch at its current point in history, and click a history point to visualize the design at this point.
    You can now create a Version from any point in history without having to restore that history point first. You can also create intermediate Versions before existing Versions. Comments can also now be added to existing Versions to document your designs better.
    Wistia video thumbnail - 151 Versions from History
  • viru
