How can I Un-Derive a part?
jon_woellhaf
Member Posts: 92 ✭✭✭
Once I have created a part using the Use functionality, how can I then completely disassociate the part from the one it was derived from?
in this sketch , Click "show constraint" first, the you can delete the constraints which are made by "Use" and add some new constraints manually .0
