Sketch fillet bug?
nocry3nocry3 Member Posts: 30 ✭✭
Hello,
I create the following sketch and tried to add a fillet to the bottom left 'yellow' point with r=0.75. But I couldn't enter the radius and get an error? Does OnShape try to use the default radius of 2?
    edited December 2016
    @ralf, You could not able to enter the radius and get an error after selection of point because previous fillet given value is 2 which is saved in history. Currently your sketch thickness is 1.8 so you cannot give fillet value more than that.Therefore you need to select edge not point to give fillet to the bottom left 'yellow' point with r=0.75 . Please refer below video for more detail.
  • nocry3nocry3 Member Posts: 30 ✭✭
    Thank you for your help. In my opinion, the behavior of Onshape is not consistent here. Create a fillet should only create a fillet and not also meassure it. Draw a line for example does also not draw a line and meassure in one step.
