Evaluate FeatureScript request returns empty BTFSValueArray instead of face.
max_borsh
Member, Developers Posts: 14 ✭
Hi everybody!
I want to determine the geometryId for existing face (upper face of extrude).
I have featureId of extrude that I got from response (feature -> message -> featureId. "FjEqUFlhNuPViCq_0", for example)
I sent evaluating FeatureScript request like this:
P.S.: documentID, workspaceID, elementID, serializationVersion, sourceMicroversion were added with evaluate FS request.
Thank you in advice!
"FjEqUFlhNuPViCq_0", false), EntityType.FACE))); }
function(context is Context, queries){ return transientQueriesToStrings(evaluateQuery(context,
qEntityFilter(qCapEntity(newId() +
but in response I have only empty BTFSValueArray. What am I doing wrong?P.S.: documentID, workspaceID, elementID, serializationVersion, sourceMicroversion were added with evaluate FS request.
Okay, I did it.
I created a custom feature with this call after the extrude feature via API was created. And I see the face that I need through debug. I can even get the transientId by using transientQueriesToStrings and println:
But If I use same request via API (using C# HttpClient) it returns nothing (json that doesn't contain notices(errors) but contains empty BTFSValueArray).
Another requests I sent (determine geometry of front plane, create sketch etc) worked fine.
If you remove the sourceMicroversion field from your request, you will probably find this does what you expect.
It's exactly what I need!
