Sketch entity copy problem
SledDriver
Member Posts: 116 ✭✭✭
Try as I might, I don't understand what is going on here.
In this drawing https://cad.onshape.com/documents/5886c8af08ee0a0fe07320c1/w/b77b7bb9d77a77b8740df4fe/e/0ce9691cf8f7377345d8bfc1
I first sketched the Original lines which are fully dimensioned and constrained, fully defined and referenced to the origin.
When I do the first copy of the entities the copy is at first not fully defined as expected until I give it dimensions from the origin, then it too becomes fully defined.
However, When I do the same to the rotated copy, including dimensioning the angle of rotation, the entities stay mostly not fully defined, and I cannot see why. All the constraints are still present, and the dimensions, but it remains mostly blue.
Can anyone explain this for an OnShape novice. I've researched at length and just don't get it.
Cheers,
John
Cheers,
John
You're missing the dimension of the width of the base. With that added the rotated sketch becomes fully constrained.
In the original, the base width IS defined - I dimensioned half the base and mirrored it.
Also that dimension is maintained in the first copy. Just not in the rotated copy.
I don't understand why one would work and the other fail just apparently because it is rotated?
Here is a copy process of the entities. So far we've copied and pasted and have started a rotate function. Note the 46.198 dimension:- at the base.
As soon as we click to accept the 25 deg rotation the dimension is removed.
I'm trying to ascertain whether it is my lack of understanding or a bug. The mere fact that the outcome is different just by adding the construction line is a bit worrying!
It leaves the questing, when is a fully defined object still fragile... Doesn't seem too good.
Great to see an immediate response from OS.
Cheers,
As a workaround until the bug is fixed, try to avoid adding those before transforming a sketch.
