Loft issue
fma
fma Member Posts: 87 ✭✭
edited February 2017 in Community Support
Hi!
I'm trying to use the 'loft' tool, but I'm unable to do what I want. Here is a simple case:
https://cad.onshape.com/documents/745756e8a13804d0078eb51c/w/27a362bdfeeae4d6bc3de5a1/e/0fea75d1e3af1eea2a2a2d56
How can I make the vertices from one sketch match the correct ones in the other sketch, as I don't have the same number? I don't understand how does the 'Match vertices' tool work...
Thanks for your help.
  • Narayan_K
    Narayan_K Member Posts: 379 ✭✭✭
    fma , Since it has different vertices we are not getting expected result.
    As a work around i have divided both sketch into two and lofted separately as below,
  • Narayan_K
  • Narayan_K
  • Narayan_K
    Sorry for the multiple messages.Since it has showed me error while posting comments.i pressed post comment button multiple times.At last there are 4 same comments.
  • fma
    Ok, I see! I have tried to add some simple points, on the 'sketch to' rectangle, but it didn't work.
    BTW, adding the central line on 'sketch to' solves the problem without the need to use multiple lofts.
    Thanks!
  • chris_8
    chris_8 OS Professional Posts: 102 PRO
    Thanks!
    Instead of adding simple points, I suggest using the Split tool (in the same drop-down list with Trim and Extend).    I didn't realize there was a difference between Split and Point until watching one of Cody Armstrong's awesome instructional videos a few months back.
  • fma
    Even better. Thanks for the tip!
  • fma
    Ok, now, I have the 'self-intersecting body' issue (not on the above example). I read some other posts related to that problem, but I have to admit that I don't understand what it means...
  • chris_8
    That basically means somewhere the loft would fold in on itself with your current sketches.  Probably the loft you're imagining doesn't do that, but you need to provide more instructions for onshape to follow so it will follow your idea better and not intersect itself.  That's where guidelines become necessary.
    There's something else that took me a while to pick up on, which matters for guidelines in lofts:  Pierce works better than Coincident for attaching guidelines to profiles.
  • fma
    Ok, I will have a look at guidelines. Thanks.
  • fma
    Another thing I don't understand: why does from/to order matter?
  • chris_8
    Order matters because you're not limited to two profiles.  You can loft through 3 or more and Onshape needs to know which way to go
  • fma
    I see!!! I didn't know it was possible to use more that 2 profiles! Great.
