Selecting line before construction line
eric_20
Member Posts: 1 ✭
Is there a way to set Onshape to select a regular line before it selects a construction line that is coincident with the regular line?
From the Help:
"Use Select other to select entities (sketch curves, part faces, etc) that you might not be able to see in the graphics area because they are obscured by other entities."
