Selecting line before construction line
eric_20
eric_20 Member Posts: 1 ✭
Is there a way to set Onshape to select a regular line before it selects a construction line that is coincident with the regular line?
  • Narayan_K
    Narayan_K Member Posts: 379 ✭✭✭
    @ eric_20 , Do you mean selection filter to select only solid lines? At present Onshape don't have that option.
  • Hakro
    Hakro Member Posts: 67 ✭✭✭
    There is no selection filter. But you can use "Select other" from the context menu.
    From the Help:
    "Use Select other to select entities (sketch curves, part faces, etc) that you might not be able to see in the graphics area because they are obscured by other entities."
  • john_mariner
    john_mariner Member Posts: 6 PRO
    similar problem and prior answers do not seem to apply.  So far, only a sketch.  Solid line arcs are on their dashed construction circles.  I need to make an array of the arc segments, but when clicking always and only get the whole circle.  Only want the arc segment.  What to do?
