Can you export a model in free trial version of onshape?
craig_fazekas
Member Posts: 2 ✭
its been awhile since ive used onshape, last time i used it was a few months ago, before the plan changes i've been reading about.
would like to know if i can still export to STL. when i go through the process, as i have before. and click download. the export window disappears... and nothing happens.
Yes, you should be able to export to STL. Can you share a link to your document or provide more information on the steps you are following?0
@craig_fazekas, Yes You can definitely be able to export to STL. I am also using free trial version of Onshape. I am able to do that. Kindly refer below video for more detail.
