How to go back and forth between solid and surface model?
Ben_Misegades
Ben_Misegades Member Posts: 133 ✭✭✭
As an example, say I model a solid cube. In SolidWorks, I would simply pick a face, hit delete face, and now I have an open box made of zero-thickness surfaces.
To go the other way, I could add a planar surface defined by the open side of the box, and then knit the two surface bodies together and tick the option to create a solid, and now I have my solid cube again.
Is there no way to do this in OS presently?
