Will there be liquids added to the materials?
elizabeth_new
Member Posts: 2 ✭
I would like to be able to find out the fluid ounces that a container will hold. I know that I can calculate the mm cubed provided into fluid oz, but will you be adding a liquid (like water) to the materials?
many thanks!
many thanks!
A while back when materials were first introduced I was left with understanding that next implementation would be custom materials.
If you have special requirements, let Onshape know using feedback in cad menu so they can evaluate if there are others with similar needs.//rami7
If you have special requirements, let Onshape know using feedback in cad menu so they can evaluate if there are others with similar needs.//rami7 -
I have left some feedback, thanks. If you have any other suggestions please let me know.
