Can someone help me get my project designed?
dan_arnold
Member Posts: 1 ✭
Hello,
I am new to 3-D CAD and having a tough time getting the hang of it. I watched quite a few videos, read through the 617 page Manual, tried many hours to get it accomplished, yet still stuck. I have a public design called Test5 that I have partially completed. The next step I am trying to achieve is to make a concave extrude/delete along the bottom from the arc of the lower 3 point circle on the right face, all the way to the bottom left. No matter what I do I cannot get the arc of the lower 3 point circle to be coincident, so it is not attached to the rest of the object and that alone is preventing me from proceeding.
Once I get past that, I intend to separate the bottom to fit as an interlocking cover, make the solid into a shell so that I can add/mate internal standoffs from the top (I started a standoff on "Test3"), add/mate matching standoffs for 6-32 FHS on the bottom cover and then add/mate PCB card guides, extrude/delete holes in the shell for parts and other internal modifications to get this ready for 3-D printing.
Thank you for even looking at this, more thanks for your assistance.
Dan Arnold
Dan Arnold
Hi Dan,
Please post a link to your public model here so that the community can get some context on what you are asking and begin to help you out.Jake Rosenfeld - Modeling Team1 -
This?
https://cad.onshape.com/documents/58bda3e0be6d560f7d16fd0a/v/5461d5e836fa399ed8ad27fc/e/e5e8581af405491f6598fed9
You need to make your arc a solid (close it in). And also use the "use" command to reference your part's other edges.0 -
@dan_arnold as much as I'd like to step you through the whole project, I unfortunately have this silly thing called a job that won't let me do that right now
That being said, I copied your Test5 project and went through and cleaned things up. You had a lot of unnecessary steps in there, undefined sketch geometry, etc. Have a look at what I've done in the link below and see if you can spot the differences. I think this gets you through the first paragraph of your question.
https://cad.onshape.com/documents/58bda43d1619200f7d9d0eb9/w/b69732083b8a90eaa9116d0c/e/9c03a17ccceae318b397e695
1
