Part breaking up in assembly mode when moving.
How do you get a part in that is created by a sketch, extruded, and rotated to move unison when you're in assembly mode?
  • Jake_Rosenfeld
    Jake_Rosenfeld Posts: 1,646 image
    Michael,
    It may be easier to see what you're having trouble with if you post a link to your document in this thread with a description of what you are trying to do.  At a first guess, you could use the assembly 'group' command to make sure a group of different parts moves together in an assembly:
    https://cad.onshape.com/help/Content/mategroup.htm
    Hope this helps!
