Best strategy to make features robust in boolean operations?
dave_cowden
Member, Developers Posts: 470 ✭✭✭
I'm encountering a problem I've had many times, but I've never really found an elegant way to solve it.
When making a feature that does boolean operations, there are many opportunities for BOOEAN_INVALID, due to line-on-line geometry.
Usually, I've resorted to ugly 'add 0.0001*meter' kinds of solutions, to make things i'm subtracting a bit larger, a bit smaller, etc. The goal is to shield the user of the feature from the need to fiddle with the geometry to make it work.
Is there a canonical/elegant way to solve this kind of issue? Of course its easy to simply notify the user that an adjustment is required, but _usually_ the user's intent is clear...
for example this shape removes a corner, and has the top sketch exactly lined up with the side of the block. But it does not produce BOOLEAN_INVALID
But frequently when I do the same type of operation in FS programmatically, I"ll get BOOLEAN_INVALID in this same type of case. I have become occustomed to adding small dimensions to the cut to make sure it is not line-on-line with the side, but that has always seemed like a hack. Then it occurred to me that there might be a smarter way, because i dont have to do it in the GUI.
@konstantin_shiriazdanov yes in my case i wrap with try, and in fact I report a nicer regenError to the user, highlighting the features that are wrong. But i want to do better, and actually make it 'just work'.
I'll see if i can create an example
Besides adding a tiny offset, I can't get it to work.
To explain a bit more: Either of the cases below cannot be extruded into a single body (even if there's geometry properly joining them elsewhere) because the adjoining edge would be non-manifold.
Formally, a manifold 3D body is one where a sphere of sufficiently small radius cannot be placed anywhere such that it intersects more than two regions of space (i.e. inside and outside the manifold body). Along the extruded edges above, you can place a sphere that goes inside, outside, and back inside the resulting part no matter how small the radius of that sphere, so the result is non-manifold.
A good heuristic for identifying most non-manifold bodies is an edge that touches more than two faces.
Note that the everything above is all fine and dandy if the edges are on different bodies (since you have two distinct edges each touches two faces). It's only when you need to boolean them together into a single body that it's an issue, at which point you need to decide whether the result you want has a small gap or a small overlap.
It's easy to throw up my hands, and give a regen error, combined with highlighting the problem faces. But that doesn't really make it easy sometimes for users know what exactly they should do to fix it. And, even if they do, it is extra, icky work.
I suppose that arbtrary, too small to notice offsets are the right answer in my case.
