Can i translate/copy a circle(or any other entity) along a spline or raduis?
samuel_studach
Member Posts: 3 ✭
In the sketch mode: I want to translate or copy a circle along a spline or a radius. can i translate only linear or circular?
thanks for your help!
Not in a sketch that I know of
but pretty easy outside of a sketch:
https://youtu.be/YupquIPtjVM
Of coruse you will need to calculate the length of your sketch... sorry5
Yes,
Select all the lines you want, then copy and paste,
then make one of the vertices coincident to the spline
https://youtu.be/CF6ziN0_T3A
thanks for your answer. it helps me a little bit. but i want, that i can say: 5x circle Ø0.5" on a spline with a length of 10 inches. so i have every 2 inches a circle....
Of coruse you will need to calculate the length of your sketch... sorry5 -
that was very helpful! thanks a lot!!!0
Glad I could help
