Making a hole at a specific angle
jani_oinonen
Member Posts: 3 ✭
I need to make a hole through a plate at a certain angle around two axis.
- The first hole, from left, shows a normal hole right through the plate.
- The second hole, shows a hole at a certain angle that I made with a "line angle" plane where I drew a rectangle that I extruded. This is half way of what I need. I need to add yet another axis to make the hole also tilt 45 degrees outwards.
Can you not do the same again and build an additional rotated plane off your 1st new plane?
HWM-Water Ltd0 -
Sorry, I don't think I understand. I understand what you mean, but not how to do it in practice.0
Thank you Ben_Misegades! Made a copy of your document and will go through it step by step.
Ok, looked through it now and that solves my problem, albeit in a tedious way.0
